D-Link 504G Help with eMule
Cosmic_Nomad
Earth,
Hi all was wondering if some one could help me find out why i cant get emule to work with the following router DSL-504G
The help pages are only giveing you a "WALK THROUGH" for every model of D-Link routers but the 504G model [:0]
Which can be found here for other user's that need help:
http://support.dlink.com/faq/search.asp?question=open+ports
or
http://tomyy.preinheimer.com/asp.php?view=dlink
I am no IT expert so some screen shots would be great
And as i see that D-link larnies are trolling the forum would you please put some screen shots on the above on your website just like you did here http://www.d-link.co.za/adsl_modems.htm but with mIRC emule games etc would be nice .........
Thanks for any help
Got it working.. no thanks to anybody
This isn't the best solution though,
setting a NAT RDR rule, problem is
when the router gets assigned a new IP
from the ISP, I have to recreate the rule.
So if anyone can help with a better solution it would be appreciated
[Think i found a way and put the IP block range owned by Telkom in ][Is this the correct way ?]
_______
UPDATE:
now I notice that DCC Send from mIRC is crashing the router and it
has to be powercycled!
Anyone know if a firmware update will fix this? or any other workaround.
______
UDATE:
Newbie question, but now my settings in NAT RDR aren't having efect
and I notice that the rule i created has disappeard. Is this a Reboot
without commit? I also saw in a manual, about saving the configuration... where is this setting in the web config ?
Cause not even do I have to set the rule everytime the ISP changes is,
now it's on a maybe crash on DCC.[Fixed with commit and reboot !][mIRC still broken ;(]
______
UDATE:
Dlink 504G is not giveing me droped connections been on eMule now for 24 hours no problems and downloading @ 25.4 Uploading @ 12.7 nice little router for now.........
Please email this supplier if you have any suggestions:
_______________
Drake Computers
[email protected]
_________
STOP SPAM! Countermeasures
http://www.sneakemail.com
I never could get emule to work at decent speed (Netgear modem).
Have you tried Kazaa Lite K++ with KaNat? It can handle the IP address change and gives good download rates.
Emule is working fine:
12/6/2003 13:43:49: New ClientID: 37640370xx
Kazaa isnt my first choice for downloading "Game Demos "
but thanks anyway [:)]
Please go to www.dlink.co.za and download the new patch for the DSL-540G if you have problems with a dropping line every few minutes, and in the web config, please go to admin -- commit & reboot, first commit after making changes and then reboot the unit. Any further questions, please contact me, I'm glad you got my mail about the NAT rule and that it is working.
Regards,
Herman J.v.Vuuren
D-Link SA
Tech Support
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Cosmic_Nomad</i>
<br />Got it working.. no thanks to anybody
_______
UPDATE:
______
UDATE:
______
UDATE:
_______________
Drake Computers
[email protected]
_________
<hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">
Best Regards,
Herman Janse van Vuuren
Tech Support
D-Link South Africa
Well Well Im very taken back D-link has GREAT support :)
Not many other Product vendors are going to Telkom Test Labs to do further tests .......
Email Support was Quick.....Thank you
Good to see that Herman Janse van Vuuren from D-Link South Africa is moveing in the correct direction with top notch tech Support !
Keep up the good work Herman [:D]
Best Regards T
Most Welcome, any further questions or problems, please feel free to contact me at any given time.[:)]
<br />Well Well Im very taken back D-link has GREAT support :)
Best Regards T
Best Regards,
Tech Support
D-Link South Africa
Hi,
I'm also using D-Link router for ADSL. Have problems with Ports 80 / 110 & 25. From Port scans, it seems Telkom is blocking them higher up.
It doesn't matter what I do on my network re Firewall settings. Even if I completely disable same, it has no effect. The port scan quotes a completely different IP to the dynamic "front end" IP of my router which is always 165.165.*.*. It quotes something like 198.*.*.*.
Question - Does Telkom block the ports? If so, which SP does not?
Question to D-Link - I've tried opening ALL ports on the router to RDR to my server - still no luck. Any magic trick I can try?
Thanks,
Jan Koster
Can somebody tell me (in detail)how to setup my 504G
to wor with edonkey?
Ashook
Dear Iceman,
For what purpose do you want to open the ports?
Please visit www.dlink.com.sg go to tech support on that page click on setup procedures, go to broadband devices and select DSL-500G, this will help you with the opening of ports and services, it is a power point presentation.
Best Regards,
Tech Support
D-Link South Africa
