D-Link Access Point Problem ???
DarkWater
:confused:
I've got a weird problem....I wanted to use my old D-Link AP but it's not working anymore :(
Basically what happens is the power LED starts blinking as soon as you connect the power adaptor.....it blinks for about 5 seconds.....and then dies...2 seconds after that it starts blinking again...and after 5 secs....etc..etc..
I did a reset at the back but no luck... help plz :( :confused:
Sorry m8 cannot help, but i put 3 D Link access points in our offices in jan and each and every one of them is now history, will never use them again (also had direct contact with D Link and they could not help)
For the reset try holding the reset button in for 30 seconds apparently a quick push on the button does bugger all, 30 seconds gives a full reset.
Power issue? Check the connections on the little connector, may be loose?
Unfortuantly it looks as if from what I can see that your Flash Memory has become corrupt probably from Power Fluctuations. If this is the case the only thing that you are able to do is send the unit back, as you can not reflash them with new versions once they have become corrupt.
