D-Link ADSL FAQ's
Elf1nDrak3
Any queries on the ADSL product (technical) feel free to ask or complemant or complain. (Products DSL-300G, DSL-300T, DSL-500G, DSL-504G, DSL-504T, DSL-604+)
Best Regards
D-Link Africa Technical
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Elf1nDrak3</i>
<br />Any queries on the ADSL product (technical) feel free to ask or complemant or complain. (Products DSL-300G, DSL-300T, DSL-500G, DSL-504G, DSL-504T, DSL-604+)
Best Regards
<hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">
Im getting adsl next week. I want a product that does:
802.11g
couple of lan ports
wan port?
be able to plug in higher db antenna
*built-in adsl modem*
NAT
Firewall
and all the other relevant sh*t [}:)]
Whats the best dlink product for me?
If you cant combine that all in one please recomend a basic adsl modem + seperate full featured wifi AP.
Any news on wimax products shipping?
TIA
Is going to buy dlink because they take the trouble to come to the customer! [}:)]
-Information anarchist-
www.sentechhatesfreespeech.org.za
I support:
www.poopband.co.za
www.hellkom.co.za
Best Regards
Hey still waiting for an answer dammit [}:)]
I support:
www.poopband.co.za
www.hellkom.co.za
I've got a complaint about the 300T - mine doesn't work! I've really tried everything that I (and the D-Link techies) can think of. I've just mailed the D-Link guys, so this should be a good test of their technical support capabilities - I'll let you know if I'm impressed or not...
hArTH
You'll need a DI-624 and a modem.
This will handle all your needs.
Nick
Technical Support
D-Link SA
Dsl-504t
Hi there,
I had alot of problems with the Telkom ADSL POTS Router (Piece of crap). So yesterday I got the DSL-504T D-Link ADSL Router. It works great. No more problems with my ADSL connection... I can do everyting I want to do.
Well there is one little problem with the DSL-504T. Everytime the router is unplugged from the power outlet it loses its configuration... It is a bit anoying reconfiguring it every moring when I want to use ADSL!
Cant find anything about this problem on D-Link Knowledgebase.
Any ideas?
PJ
PJ
One thing you've got to keep in mind. This device is a EEPROM orientated device. After you applied your settings and configuration you'll need to go to Tools => System Devices and click on the SAVE ALL button, then click on the BACK button and then on the RESTART button for the settings to be permanently saved to the EEPROM.
