I bought a D-Link DSL-2500U and can't get port forwarding to work. I have a server on my LAN with a static IP address. I can ssh to the server on port 22 from the LAN. On the DSL-2500U I add a virtual host with the local static IP address and remote and local ports set to 22. There is a remote IP which I don't fill. Save and reboot the router and then try to ssh on port 22 on my WAN IP address. Getting connection refused.
It works perfectly on my old modem/router if I swap the routers.
I upgraded to the latest firmware for the DSL-2500U (T1) and also downgraded to the original firmware again.
Also factory resetted a few times.
No luck. Am I doing something wrong or missing something?
