D-link DSL-2760U pppoe auto-reconnect possible?
Slip
I have D-link DSL-2760U and each time the pppoe link goes down the modem does not automatically re-connect. I can't find any settings to enable this either. Has anyone else experienced this or know of an alternative firmware I can run to fix this. It's really annoying as FNB connect resets all there accounts every morning at 4:00 and it disconnects the pppoe connection.
The only thing I can think of is "Keep alive PPP connection" should be checked and "Dial on demand (with idle timeout timer)" should not be checked.
(Advanced Setup > WAN Service > Edit > Next > Next)
Thanks, "Keep alive PPP connection" is enabled but still not working.
I'm having the same problem... same router... with Afrihost...
Have to reboot the router every morning :(
