D3 - Wizard help
The only things I see missing are more damage and some health regain like loh or life steal etc... all res could be better but ive seen strong wizards with less.
Your amour is super low...My DH has over 4k armour...you have only 1k.. I think that's your problem. But im no expert on wizards..
Armour is ok, my wizard has 4k Armour as well but I can play mp3. But I suppose the more armour the better.
See he fixed. He now has 4k armour.
I think you need a tad more DPS.
What build are you really going for? Frost nova or Archon?
Go for ONE build.
Go for ONE build.
Could be the build. I copied filthy's :D build and the wizard got much easier. Was doing it all wrong.
Lol, jaaaaa. Filthy's Wiz is uber though.
But having a dedicated build boosts your char by 100% easily. I struggled with monk on MP2 till I read up on some builds, gear a bit more towards them and then all of a sudden with less than 1 mil spent and a new settled build I could do MP5.
Thanks a milion guys, My armor was at 4k and didn't change a thing yet...
Who is Filthy and where is his build?
Here's a link to my wizard:
http://eu.battle.net/d3/en/profile/Vrotappel-2351/hero/618094
I suggest you get All Resist on some of your gear. Start with pants - look for good Depth Diggers.
Then look at Zubimassa set: ring, shoes and chest for AR and Int.
I would also suggest a black weapon for extra DPS. Google black weapon.
Thanks alot man,
I appreciate your help
I really like rhis archon build, insane damage, CM build needs to much concentration on pressing the right buttons
Get yourself at around 350-400 AR at least 3.5k armor and anything above 80k unbuffed dps, you should be running MP1 with those basic stats!! and YES to triumvirate and black damage weapons!!! That makes a very BIG diff!!! You can find pretty ok Echoing furies at around 2m if you look hard enough! Also getting CC up to like 45% makes it ALOT easier as well! Currently I'm running a Archon build, buffed dps is around 180k CC at around 47-53 if I recall AR about 340-380 and just over 3k armor.
If I do a CM build I can solo MP3(meybe even higher, haven't tried I hate CM - cookie cutter is awesome!), so those stats should sort you out!
Yeah your problem is running CM for what I assume is solo play?
CM is only suitable for group play unless you're able to dual-wield Visa's and get the best of the best. Archon is gonna be the most viable build to solo with but you'll wanna try pick up a 13xx Skorn with Life Leech since only Sheet DPS matters in Archon form.
Really enjoying this thread. My Wizard also needs critiquing and some advice. Still work in progess.
http://eu.battle.net/d3/en/profile/Idznak-2500/hero/2682849
You should be able to pick up a better ammy easily for 1-2 mil.
Also you should look into upgrading your shoulders as they are not very good.
Perhaps get the account bound crafting plans... The intel. shoulders roll with a min 200 intel. + 4 randoms... I am sure you will be able to get a pair first craft you do. Archon Shoulder plans of intelligence.
Here we go: http://us.battle.net/d3/en/artisan/blacksmith/recipe/archon-spaulders-of-intelligence
thank you anamech and bradrap, I find the CM build a bit dificult to play but I'm getting use to it, the problem persist when not facing a crowd and the lack to see what is actually going on on the screen!
anyway I'm atm gold farming to get better gear all my gear atm has gold find (didn't focus on the other ring):whistle: taking it to 258%GF I run through nightmare act3 MP10 with ease, didn't play long last night but made a sturdy 200k in about +-20min, I try again tonight with a little longer run!
