Lightscribe
Banned
DA makes waves with water report
April 16, 2010
The Democratic Alliance's deputy spokesperson on Water Affairs Annette Lovemore provoked a storm of protest, not least from the Water Affairs Minister Buyelwa Sonjica, when she livened up the debate on the department's budget in Parliament with a few choice comments on the "Green Drop" report on the state of waste water treatment in this country.
The problem was that the report has not yet been published.
Sonjica was on her feet instantly to complain that Lovemore was taking advantage of a courtesy copy that as been sent to her ahead of time, and that was wrong.
The chairman of the debate, which was taking place in an extended public committee of the National Assembly on Thursday, said that the minister was not raising a point of order, and that Lovemore should continue. She did, with obvious relish.
She pointed out that only 53 percent of wastewater works were actually assessed; 47 percent were not assessed because the local authorities were not obeying the call to be assessed, or their officials were not sufficiently confident in their levels of competence to be subjected to assessments, or were not managing the services according to expected requirements and were therefore not in possession of management information required for Green Drop assessments.
"These are not reasons for not assessing," she said emphatically. "These are reasons for a score of zero and for urgent intervention."
Lovemore added: "So, while the Minister will be announcing shortly that 32, or 7.4 percent, of works actually achieved Green Drop status, she should be announcing that only 3.8 percent of works comply fully with requirements."
"The minister will also be announcing that 45 percent of the works assessed scored better than 50 percent. In fact, however, 76 percent of the works scored less than 50 percent, and 47 percent of the works, in effect, scored zero."
Replying to the debate Sonjica declined to be drawn, saying that the report is not yet published and she will not comment until it is.
http://www.busrep.co.za/index.php?fSectionId=561&fArticleId=5432270
Even a civil war, actually a full scale war, cannot do the damage, that the anc has done, to the infrastructure of SA...
Let's not even mention the long term psychological damage, specific to the various ethnic groups that comprise SA...
