I am at the end of my tether and hope I can find a solution here. I had a dashcam in my vehicle for many years. It was mounted to the windscreen with a double sided adhesive pad that came with the device. It stuck so well that I had to cut the mount off the windscreen with a razor blade when I got rid of the car.
The problem is now that I cannot seem to find any way to reliably stick this mount onto the windscreen in my new vehicle. I have tried every kind of double sided tape I could find, from the cheap crap to the name brand expensive stuff that's allegedly UV resistant and designed for outdoor use. None of them have successfully held up the dashcam for more than a few weeks at most before failing miserably.
As a last resort I forked out more than R100 for some Pratley Quickset adhesive which I was assured by the salesman and the suggested uses on the box is designed to permanently attach rearview mirrors to a windscreen. I followed the instructions perfectly and ensured that the surfaces were completely clean. I even left the mount overnight without the camera attached to give it the best chance to cure without any weight but it immediately came loose when I went to attach the camera the next morning.
Do you have any suggestions for a specific product you have used that will definitely work as I'm tired of wasting my money on false promises?
I'm starting to feel like the double sided tape manufacturers are just taking the piss.
