Data management settings
murraycraig69
What must my wifi router's data management "Data Type" be set to? "Time" or "Data? Whenever I log in it says: "Your data/time used exceeds limit. Do you want to disconnect..."
Disable it.
That's for if you only have a certain number of gigs or minutes. It's meant to prevent you from paying for out of bundle data.
Can you disable it instead of picking between the two?
Uncapped should not need data management.
I'm not sure. Our router flashes a blue light to show it is working. After every third flash it flashes red twice very quickly then resumes flashing blue. I'll try and see if I can disable it .
I want to show you the set-up of our site. See attachment. The "Data management" is in the "Statistics" function.
Just disable it if your data is uncapped.
If it wasn't meant to be enabled why enable it at all? I thought you might be able to help me and see if any of the settings that are shown in the screenshots are correct. So can you?
It looks like you are limited to one hour internet.
Disable it unless you want to limit your internet usage.
There is no limit. Its constantly going, there is never a lapse in connection. Where do I change the setting? You seem to know your way around these things.
Sorry, I have never worked with this router.
Maybe the data type dropdown?
