F
Fudzy
Guest
Hi guys,
I'm looking at getting a new data projector for work and i see some are coming with 'wifi' support. Does this mean that you don't need to have your PC physically connected to the machine? This is ideal if so as the projector is going to be mounted in the roof and its going to save money on having cabling put in.
Anyone had any experience with these? I have an ASK C170 which you can plug a flashdisk into but its pretty rubbish as you need software to convert the powerpoint presentation etc to images to play on the projector.
