datacard not connecting.
fismail
Centurion, Gauteng, ZA
Using Windows Vista X64.
Dialling up using Ginggs E620 Tool or the MTN Dashboard software it just gives me error 638 all the time.
"The remote server is not responding in a timely fashion"
Pickups up 3g and EDGE coverage perfectly in all areas that I goto.
Both "internet" and "myMTN" apn's don't work.
Used to work perfectly , not sure if Windows Update caused a booboo.
Drivers for datacard are 64 bit versions , USSD commands using Ginggs tool work perfectly as well.
Dial number is *99#
Any ideas ? My last successfull connection was 15 April 2008 via the datacard and oh I do have a full 2gb available according to the USSD menu and my card is'nt suspended as I can make and receive calls and I still have the 2gb bundle loaded onto the card.
formatted laptop , installed Vista Ultimate 32 bit , downloaded selected windows updates.
datacard connecting properly again.
i reckon after i installed that 64 bit drivers and then a windowsupdate happened that something got corrupt somewhere.
