DayZ connection problems
Rainbow Dash
I cant seem to connect to DayZ it gets server connections errors.
Any help?
Does it give you that pop up where the button only says "Restart" ? . If so just exit dayz , exit steam and go back in , if that does not work . Just restart your pc
no it just says "Cannot connect to server" even if I manually enter the servers name.
