DC++ Hub
kaaskop
Paarl
Ok, so ive started a dc hub on my PC to test iburst throttle. If someone wants to connect and see if they can download something youre welcome. I would like to hear from Iburst ppl thats allready throttled.
IP: 41.208.224.225
Oja, iam using DC++ 0.75 and i can connect to myself.
will check now...
btw: use dyndns, no more ip address issues :)
Edit: An existing connection was forcibly closed by the remote host.
Disabled windows firewall and antivirus. See if you can connect again plz.
A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond
Thats with justshare.getmyip.com
Mmm trying to connect from work. Got the same message. Dunno whats wrong. A well ive tried:mad:
