DC solar cable length
Tongs of Destiny
Just a quick question. Retard me didn't double check where the DC cables come out from the solar panels, I though they were at the "top" center of the panel. Alas, they're each side.
I'm running them into a micro-inverter so all the 4 panels cables must reach into the inverter.
Is it ok if I extend 1 cable on the panel say 1m, the other stays the same? So under a panel lets say the positive cable is 1.2m long and the negative cable is 2.2m long.. :rolleyes:
oh and one more thing, some of the cables on the back of the panel need to be extended by 50cm or 1m, am I allowed to cut the wire on the back of the panel and just splice a 4mm2 solar cable in there? Do I really need to go and buy more MC4 connectors and join all that to extend a wire 50cm to 1m max?
Joints are bad and you really need to avoid them if you can, its not that one cable is longer than the other by a meter, that is negligible, the problem is that a joint is a weak spot, it will no longer have the insulation and protection, it will get moisture over time and can affect the system.
Just get the MC4s and do it right.
Yes there is no issue with having different cable lenghts on PV. High voltage and low current means that voltage drop is not an issue. I would suggest you buy some MC4 connectors and make some extensions that plug into a panel lead and into your microinverter. If you cut the original MC4 off the panel you lose the warranty on the panel
As with batteries, surely it is best practice to ensure the pos and neg wires are the same length?
It is, but as long as the difference is kept to a minimum it won't have an impact. It is much more important in batteries, especially if you have a couple of them, because since you are charging them any difference will result in unbalanced batteries overcharging and undercharging.
It's slightly different with solar, it is supplying power, the panels are not identical anyway so the extra resistance will be just that, at a meter difference it won't even register on your multimeter. In a string of series panels it will be just the panel that's supplying 0.00... something volts less, which is a non issue, even in parallel it won't be enough to make any noticeable difference. Solar is also generally at high voltage so it will be less affected, unless you have smaller panels where every volt counts.
ok cool thanks for the info, I will buy some 4mm solar cable and I found a pack of 10 pairs of MC4 connectors on TakeAlot, I will get knitting next week :) Now to try and lug all the panels onto the roof... this should be fun :sick:
Use a Dektile. Much easier takes 16 cables. Tile roof get the Lead one.
Use a descend crimper, no side cutter. In the long run you will have better connection.
I would like to solder those point for durability.
I've got a corrugated metal roof, with the micro-inverters I only have one AC cable running down from the roof into the house :)
I can't believe how expensive a solar crimping tool is... I only have those normal crimpers and pliers look like they take forever :( solder would be way better
what's a decent one that you've bought? The ones I see are like R1,000.... ughhh
Have not bought one yet. Need to have one for maintenance.
Try this one
Try this one
what about that? Is it a ratchet crimper that is needed?
As longs as solder does not interfere with how the metal part sit inside the connector. I wouldn't bother about the proper crimping tool if you don't have one, just make use of what you have and do a proper job, there is no pressure on the connector so disconnection should not be an issue.
I just bought one don't know if you will get it at that price again.
