DC UPS for 48V PoE switch?
Neville Bailey
Durban
I have a PoE switch that I would like to keep powered up with a DC UPS. Most DC UPS’s that I have seen only cater for 12V devices, but this switch is 48V.
Any recommendations?
4 of the small gate motor batteries in series will give you the 48V.
Take care when working with DC, especially 48V, put the necessary protection in your wiring.
Take an output from the UPS and boost it to 48V with one of these: https://www.communica.co.za/products/bmt-dc-dc-600w-boost-12-80v-10a
If you need help just give me a shout
Nah, then he's got to figure out some sort of charging mechanisim and low voltage protection for it
Thanks, but I was hoping for a plug and play device, similar to those Gizmo DC UPS's, but one that can handle 48V.
You'll have to get a multi meter and adjust the screws on the potentiometer until it is 48v...
(As it says on the spec - adjustable in 2v bands)
Minimum voltage difference is 2volts
Meaning for example if your input is say 24 volts then your output will be minimum 26 volts, you cant for example choose 25volts as your output as the difference will only be 1 volt
These type of DC DC converters are fine tuned with a small flathead screwdriver on a potentiometer and you can get pretty good outputs from them, nicely tuned of increments of around 0.1volts.
It is also good to meausre the load on the output side again once you have connected your device as there is sometimes a volt or 2 loss when under load, compared to when you were finetuning our output before there was a load
EDIT: I just see this now
  • Output Voltage: DC 12 ~ 80 V ( adjustable, O/p Voltage > I/p Voltage by 2V )
My bad, I guess it is 2volts increments then on this particular model
I know this is an old post but I am posting this to help anyone else who is searching the forum for a similar answer. I have found these 48V DC UPSes from a company called Tech-Buddies and really impressed with the unit I have bought.
There is a lot of info on the site with real world case studies which I found (through my own experience now) to be accurate.
Hope this helps
