Try putting it in the fridge in a seacled plastic bag for 30 mins.
Take it out and wipe it off before you plug it into a different computer.
If it runs... copy everything off it quick.
Never heard of this. Thanks.
googled it: http://geeksaresexy.blogspot.com/2006/01/freeze-your-hard-drive-to-recover-data.html
I've used it many times. Most of the time you won't get more than one go at it. So if does start, use your time well.
I also use a program called Regenerate Hdd. It works fairly well. You will have to get the paid version though.
I think it died.
