Dead Hard Drive
willirob
My hard drive has died - won't spin up - just dead.
Anyone recommend some in CapeTown to fix.
Cheers
Not worth it
In my experience it isn't worth your money or trouble to fix it. Except if you had some really important information on it (in which case you can take it to a harddisk recovery centre), smack it in the bin and go buy a new one.
Ask Person for prices.
Just my R.02!
I think its just the controller board on the drive - can this be replaced
Person said:
then its the drive that is dead
cr4p - so, out of interest, how would the data recovery service guys go about recovering
They usually first try to replace the HDD control, aka the circuit board on the drive. This is most likely what failed in you case. If that does not work, they transfer the platters to another drive. Then they use a fancy program to try to pull all the data off the drive and write it to a bunch of DVD's. How much data you get back depends on what failed and how.
OK - thanks: so theres a chance I might get it all back then
I recently got 'n harddisk filesystem/physical crash as well (STAY AWAY FROM MAXTOR!!), but luckily stuff was still spinning inside. Managed to recover all my data. :)
Drive is still in use, but is getting worse everyday. Happened within 6 months after I bought the damn thing, and since it was in the US, I couldn't claim the warrenty.
Weird, i havnt returned any of my 160GIG + drives, I know of the well known issues with the 40GIG and 80GIG's.
Person said:
Here's my Maxtor Drive stats: 378 Sold : 192 : Returned (within 6 months)
That's hectic!
I must say, I've been using and selling Maxtors (and Quantums) for years, never had one fail. But then, I've very rarely had drives fail anyway - one exception I can remember being a Fujitsu that was one of the ones in the batch that just died with no warning.
