OK. Will try that tomorrow.Front vented dryer? Take the back cover off and give it a good clean inside, especially around the bimetallic switch in the centre.
It runs then 2 of the 4 heating elements switch on. It then stops, the 2 elements switch off the drum then turns in the other direction I hear a relay also switch but the elements do no switch on again. I did check the thermal fuse and I get a reading when I use the ohmeter. It has 4 heating elements and 2 thermal fuses 1 which has like a reset button on the back.How sure are you it's stopping to change direction and not stopping because of overheating or a faulty thermostat?
