delimiter help
dd1313
Hi Guys
Just want to know what the most common delimiter to use when
creating a premium SMS.
Like if you need the ffg information
Business name, area, category etc what would be a good delimiter to
use.I thought of a space but that would cause other issues.Maybe a star(*)
DD
Space, else somedthing that is easy. To type a "," you have to press 1 many times.
The * and # keys are normally used to change dictionary types and world on T9
some clever coding could easily solve the " " issue... there is only a certain number of areas and categories. otherwise I would use "." or "-".
Thanks for that.How would one attend to a problem like this
jacks plumbers port elizabeth plumber wholesale.
The string will be passed as
mesg=jacks%20plumbers%20port%20elizabeth%20plumber%20wholesale.
Now to put them into there own variables...
Please help if you can
DD
use a plus sign. Most providers change the + sign with the needed spaces.
