Dell Monitor Problem
Fox1
Durban
So I switched on my monitor this morning and I noticed there's one LED/Pixel stuck on bright against a white background. Any idea what's the real issue here and how it can be fixed? I've attached a pic of the fault. IMG_20190103_101136.jpeg
Thanks. Do you have any contact info for Dell?
My work colleague had both her Dell S2340L monitors giving the same fault. Seems to be a common issue...Good luck with your replacement.
What's the actual fault here?
Supplier just replaced the monitors, no questions asked :-) It looked to be some brightness issue initially, even after a factory reset, the problem remained. Issue started in the corner of the screen and resulted in a total eclipse. Although, I have the same panels and running fine so far, touch wood.
