Delphi help
Caitlyn_10
I did a project in Delphi with multiple forms. i saved it, but now i have an error that says the multiple forms file isn't found . it has something to do with the multiple forms and it cant pick it up. could someone please help me...
pro tip - never just post "I have an error". It is a great way to piss off your future colleagues.
  • I am having an issue with X / I am getting an error when doing X.
  • This is the details of the issue/error.
  • This is what I have look at to try to resolve it myself
thanks
Hi Caitlyn, that's a better start :)
I think what would help here is if you added a screenshot of the folder where all of your project files are, then another screenshot which shows the error that you're getting.
I'm not very good with Delphi but i'm sure there are people here that would be able to help with a little more information involved.
I remember having a similar issue for my grade 12 PAT:X3: After messing it up even more, the only way I ended up fixing was recreating the forms. What a mission! Hope you get your issue sorted :)
