Deployment solutions for SME's
Jet-Fighter7700
Somewhere Different
Hi all,
Just want to get an idea what is the easiest way to deploy PC's with diverse hardware, and keeping some standardization.
see plenty out there but what is the best and simplest to set up and work with.
The Windows Deployment Services role in Windows Server is the 'on prem' Microsoft Solution. You can capture your base image from an existing PC and you can also load in drivers for different devices so that it will use the appropriate ones. If you have Microsoft Intune, you can look at Windows Autopilot.
If you prefer something Open Source, look at FOG
