Desktop build for 5k
shadow_man
Hi guys please give me an idea of hardware for a desktop build - must work out to 5k - it will be for office/email/normal type stuff.
I don't need a screen or speakers etc. Just the casing,cpu,mboard,ram,psu,gpu etc. Chassis and all that goes in it.
J
2180
2 gig memory
cheapest mobo your can find maybe something like 500 bucks, look for a cheap gigabyte or asus very solid mobo's for office use.
I would imagine onboard graphics would be fine for a desktop, don't see the need for a GPU if its for basic office kuk.
Buy a chasis with a 300w poer supply in already.
J
Well there are a number of combos you could get, I am assuming 'Normal type stuff' doesn't include gaming, so you could potentially get away with using onboard Gfx which at the end of the day leaves you a few bob extra to use on a decent Mobo, some extra RAM and a decent CPU.
You could also get a medium spec Gfx card in case you decide you want to play some games at a later stage.
Where are you located and do you mind using online stores?
CPT, have access to Rectron + Sahara.
Don't have the quote I worked out in front of me but I did have a cheapie gybyte mboard, 2gig ddr800, 400gig samsunga hdd, e8300 or some such for cpu, cheap gbyte case with gbyte 360w psu, liteon dvd writer and a ****ty 8400gs as the cheap boards didnt seem to come with onboard - was for some reason cheaper with the ****ty 8400gs when I skimmed through the pricelist...
J
That is one hell of a computer for word/email.
E5200 R1100
Gigabyte G31 R650
1x 2gb DDR800 R400
320GB seagate sata R750
samsung dvdrw R350
Gigabyte office Chassis (350w) 4 in 1 bundle R500
R3750 for a very decent office machine.
May i ask why a desktop pc would need a 800 rand box and why would a desktop pc need a 1.3k cpu? Email,internet and office work does not need something this large if you ask me.
Brawler those specs look great for a desktop pc man, perfect for daily office chores plus photoshop,corel draw etc would run well.
E5200 R1100
Gigabyte G31 R650
1x 2gb DDR800 R400
samsung dvdrw R350
Maybe get 2x2gigs of ram, even if you are going to use 32bit OS and a better power supply to be able to upgrade in the future. I assume you are not an overclocker. :D
It doesn't. He said he had a 5grand budget. So I just went for bang for buck. Something he wouldn't need to upgrade too soon. Almost everyone of these home "work" pcs end up with need for speed and sims2 on anyway.
The cores will also help if they ever wanna run more cpu intensive apps, or just more apps.
My build has a very big bang for buck.
Yup +1
Hi J
PM me and I'll give you this at cost:
Intel Core2 Duo E8400 3.0Ghz
Asus P5KPL-CM
Corsair 1024mb DDR-2 667Mhz memory
LG DVD-RW Drive
Seagate 250GB SATA2
Antec 4480 M-ATX Black/Silver chassis + 380w PSU
R4000
We can add a GB of RAM and perhaps a mid-range gfx card.
Regards
PP. :)
/Off Topic
Does Rectron Close for the December Holidays or something? i'm gonna build a 12G Gaming Rig soon - just waiting for some more cash...
/Off Topic
Just received an email from sybaritic saying that all their suppliers are closing from the 19th of December.
/Off topic
Does anyone know where I can get a Recton and Sahara price list, I have someone who can organize to buy something there now I just need a pricelist.
/Back on topic
I think you should go for Postmanpot's system, he's a reliable CT seller with quite good prices.
