Hey guys,
New to the forum. I'm about to pull out my hair, but before I do that I thought it might be smart to consult with you all.
Here is my scenario:
I live in a small coastal town, Onrusriver, where my Telkom Exchange only allows for a 2mb ADSL line. I work for a US based company as a Video Editor and so I need to edit a ton of videos and upload that to their respective channels. A 2mb line just wont cut it. We do have a local Wifi Service Provider offering symmetrical ADSL, but it's extremely expensive coming in at R800/mb.
My question is as follows:
I already have a Litebeam M5 antenna and Mikrotik Router installed through the local Wifi ISP. Would I be able to set up an additional antenna on their tower or other current infrastructure and then purchase my internet directly from a reseller, effectively cutting out the middle man? I need a really fast upload speed, and this is probably the best solution that I can think of at the moment. That's why I was thinking that becoming a "reseller" would probably be the best bet, the only catch though is that I will be using it as a dedicated line with zero contention for myself instead of selling it off again.
Please tell me that this is a possibility. I have no other idea what to do. If you maybe have other suggestions, PLEASE throw them my way. The requirements are simple; a minimum of a 4mb symmetrical line that is reliable. I need this up and running asap.
Thank you!!
Thank you!!
