drunkskunk
- May 26, 2005
Hi I wonder if anyone can help.
Yesterday my ADSL line was installed. Last night the my ADSL connection through the DG834G was working fine. Today I came home to find the ADSL link light was off and, obviously, we had no connection. I phoned Telkom and asked asked them to test the line. In the meantime I thought I would go ahead and upgrade the firmware to DG834(G)_V2.10.17.img incase that was a possible issue.
Anyway it went through the whole flashing process, rebooted and then it came up with the lights flashing consistently (between the green power light and the orange test (tick) light). NOW I can't get into the modem or at least stop the lights from flashing.
My qeustion is: Does anyboday know how to reset the unit to its factory defaults so that I can at least re-configure the unit?
I have tried the recovery tool and no luck there either.
Your help will be much appreciated!
