DGN2200v3 red light
savagezaing
Over the weekend, Telkom did some maintenance, on the lines in my area and when the lines came back on my ADSL router DGN2200v3 started went red (internet light). I gathered from my neighbours that the lines are working. The router shows line statistics and signal stats. But does not want to connect to my ISP (assuming)
I tested my line by using old adsl router and it works correctly. Even told me that my password was incorrect.
Did a factory reset with no luck. Am I correct in assuming there is not much more I can do the router is pretty much buggered?
Haha.. No I did test it with old telkom netgear router.... and it does work. :'( (wrong response to having a working adsl connection, I know)
Old router has bad wifi and disconnects when there are more that 5 wifi devices connected (Reason I bought the DGN2200 18 months ago)
Will test out the Mweb "fon" router over the weekend and see if it has some use. Other that gathering dust :)
