Hi , bit stuck on getting IP adresses from my internal DHCP server when connecting to the 5102G via Wireles.
Problem started when my Linksys access point went belly up.
So I decided rather than replace it I should use the 5102G's wireless capability which I had up till then had disabled.
My configuration has all wired workstations (3) connecting to a Switch. The no defunct LinkSys access point plus the 5102G are connected to the same switch. There are 2 Mobile users who connect Wirelessly from their lap tops. There is a separate DHCP server (also a file server). This has worked great up until the Linksys box died.
I acticvated teh Wireless connectivity on the 5102G and set teh DHCP option to Relay and provided teh DHCP servers address. Now from a laptop I can connect wirelessly to the 5102G, but it am unable to get a DHCP assigned IP address. This seems to be the only option available unless I make the 5102 the DHCP server which I am not so keen to do.
So I am now a bit stuck
Any advice? Please !
