Diablo3 disconnects when using whirlwind
Necuno
Court Jester
BUT I finally found the combination that is causing it, or so far it seems to be.
Ingame vsync on.
Now I turned this on because I was getting stuttering as soon as I hold down lmb or rmb. However when I force vsync on from display driver it is fine and no DCs yet.
:wtf:
I play with V-Sync on and don't have any DC issues on my barb.
Specific....be it.
1) vsync on ingame or on driver level?
2) do you use WW?
As I noted in the blue stickied post, I think its more to do with driver and or input because of having this:
game connection has been lost: your client has been disconnected from the server.
2012.11.16 20:44:15.202928800 de activate app 0 iconic 0
2012.11.16 20:44:15.302321800 TestCoopLevel - D3DERR_DEVICELOST
It's on in-game only, WW is on my RMB
Windows 8
Ati Radeon 6970HD 2GB
Catalyst 12.11
Windows 8
Catalyst 12.11
Win8, 670 oc (310.54), i3770k.
It only happens when I have vscync on ingame. If I set it from the nvidia control panel then there are no DCs. WW is either on 4 or RMB... doesn't matter.
Nope, but the game is on my SSD
I do have some serious frame rate drop issues in a couple of specific areas in the game after the last patch, although this is a known issue they are working on.
Kripparrian also said now that he's back to playing on hardcore, he's not going for a WW Barb because something causes disconnects when using WW and then his character will die, so it seems it's not a problem on your side. It's one of his recent videos in the last two weeks i think where he talked about it.
Can't remember if he said it started happening more after the recent patches or something. I'll look for the video and link it if I find it.
