Different attenuation/SNR values between DSLAM and Router
Austin.G
Hi I have attached 2 pictures one showing stats from my router and one showing stats from the other side of the DSLAM. My router gives me very bad readings yet I am close to my exchange which makes me believe the other screenshot is correct. I need help understanding which one is right and if my router is wrong and needs replacing. Im using the router that is given by Telkom.
OP, you need to remove your phone number.
Edit: Nevermind, was the FEC, that is fine :). Am sure someone will chime in to advise.
