Digi 2 remote control setting... troubleshooting
Apologies, we had a power cut.
When attempting to set my remote, I follow the instructions correctly, but, after holding the button on wall panel in, the light does not turn off after 5 seconds as it should.
Does that mean there is a problem with wall panel or the light itself? Or is there a relay or something else faulty?
