Digidoor 3 help
Richyricho
So I have put my Digidoor 3 into "learningmode" but I have no idea how to get it back to normal.
The amber light just flashes no matter what I do. I have contacted Digidoor(now hydrodoors) and the techie told me to power off, press and hold the enter button, power on, let it open and close twice(finding the limits), then open and close it with the remote 3 times and it will come out of learning mode, but this does not work, it still stays in learning mode.
Anyone have any idea how to get it to go back to a green light?
How I absolutely detest thee useless systems with their complicated routines and button presses, just because they are too damn lazy to provide a simple straightforward human-friendly UI.
Keep us posted as to how it supposed to work when you come right.
Sorry can't help
g
Have you tried a factory reset and then start over?
From the manual
1. Close the door manually then ensure that the manual lever is in the engaged
position (Latch Lever horizontal), and move the door by hand until it engages
with the operator.
2. Switch the power on. The controller will beep and the indicator will flash amber.
(The indicator flashes amber during set-up mode.)
3. The obstacle control is set to minimum by the factory and can be left in this
position for initial setup.
4. Press the Enter button (For a lightweight door press Enter Twice). The door will
close slowly until the floor is reached. (Note: This process can be stopped, if
necessary, by pressing the Enter button again, and a further press will continue or
restart it.) The door will then open slowly until the open position is reached. The
controller will beep twice to indicate that the limits have been established.
5. To program the first wall console (master), press the Enter button. The controller
will beep and the indicator will flash amber rapidly.
6. Press the Operate button on the Wall Console. The controller will beep.
7. To confirm, press the Operate button on the Wall Console again. The controller
will beep four times to show that set-up is complete, and the indicator will show
green (Ready).
8. Adjust the Obstacle Sensing by means of the trimmer shown in Fig.17, while
physically checking the force of the door on the shoulder. Also check that the
door is able to sense a block 40mm high placed on the floor in the centre of the
doorway. Note: This test should be repeated once a year.
9. If batteries are fitted as standard, connect these to the control board by
plugging in the two-way connector as shown in Fig. 6 on Page 17.
10. To complete the installation check that the door operates reliably and inform the
client/user of the safety features and the manual override procedure
Thanks for the reply Nemesys.
The problem comes in that I don't have a wall console. I only have the Motor which is linked to a Centurion receiver.
Smokey mcpot, I have tried to reset it, but I have no idea if it actually reset?
No matter what I try, I only get the Amber light flashing.
Try to start without the receiver fitted.
So remove receiver, reset, program without receiver attached.
If still not working PM me and I might have another solution to your troubles.
