do Broadband Level 3. Shaped or Unshaped?
but soft capped
Only found this thread a min ago, my question is this "soft cap" you spoke about , is it throttled after you reach the 3GB limit if so what speed, and at what stage is the hard cap applied if at all?
I guess from the lack of replies nobody here knows the answer to my question above.:confused:
Hardcap is applied at 6GB. There is no throttling of speed as far as I can tell.
Thanks as I needed that info to plan my downloading for the rest of the month, and did not want to sit here cutoff a few days before the end of the month.;)
