Do I have 3 phase Elec supply?
Zuluzebra
Hopefully, you guys can help me.
We have the solar guys at my house today installing inverters etc. According to my knowledge, I have 3 phase supply (outside box inspection confirmed this), and house essentials on 3 different lines at DB. Now I don't need this and want to downgrade to 1 phase only. I went to Citypower earlier today who told me I need to go to the city of JHB for a downgrade submission.
The question is, I don't know if I am being billed according to 3 phase elec supply, how would I know? I want to convert my meter to prepaid but ideally don't want to wait for another process to downgrade. So the thinking was to disconnect 2 wires outside, only use the blue, and add everything inside on the blue wire. Then only ask the city of JHB to convert to prepaid without any downgrades.
Maybe I am missing something?
What did your CoJ bill say?
Tshwane is a little different. I have 3 phase but don't get billed extra for that. They simply sum usage across the three meters and then bill accordingly here.
Just shows a normal bill without any mention of phases.
there used to be a penalty for using 3 phase that is unbalanced ,but a lot of areas have done away with that now .you will still probably be paying for a 3 phase connection though but it will probably be the same as a single phase connection ,dont scrap it .
I'm on 3 phase, if you have a smart meter (will say 3 phase on the meter btw) you only get 1 amount for the 1 meter ID. Before I had them install the smart meter I had multiple of the old analogue meters for each phase and was billed for each meter. If your house is wired for 3 phase, just stick with 3 phase. My sparky says it can get complicated and somewhat expensive to convert properly. Just have a 3 phase inverter put in, think I have a 16kw one
no thank you. No need for 3 phase or even the extra cost.
Why would it be such a challenge, they just disconnect 2 wires and bobs your uncle?
depending on age of house , it will be split up into zones to balance the 3 phase ,( if it was ever done) the only changes are inside the db , so instead of say lights and outside area on one phase , plugs on another phase and geyser and stove on the third there should be no other drastic work that needs to be done except joining the 3 circuits in the db into one .but as stated there may be issues with running a 3 phase input with only one phase some 3 phase breakers may trip if they see only a load on one circuit so the 3 phase breaker must be split to 3 single phase breakers , but that may have to happen outside .
AFAIK I don't have any extra cost for 3 phase. Bill is the stupid network charge + usage
The hardest part will be closing up the gap from the 3 phase breaker to a single phase breaker , cutting and gluing a piece of plastic can be challenging .just remember and this is a bucket that gets kicked around plenty , 3 phase can be cheaper in the long run cost wise .
Erven used or intended to be used for individual residential or religious purposes, per erf and per meter where more than one meter per erf exists
Single phase supplies (EBE821) R 0.00 R 0.00 0.00
Three phase supplies (EBE825) R 0.00 R 0.00 0.00,
may not be the same across all muni though.
Didn't see if this was mentioned but is it a true 3phase (phases out of sync) or 3 single phases split at the street
I just popped everything on one phase with the inverter. The other two phases are dormant now.
splitting a single phase supply into 3 phase doesnt really make sense , nothing to gain by it .if its tested at 380 across phases and 230 phase to neutral/earth its 3 phase .
Yeah that works fine, sparky initially suggested that, but there were concerns with load and a potential issue with how the suburb had been setup, so just stuck with 3 phase.
Yes
But it does happen, don't ask me why
Client of mine had "3 phase" which was a single phase split to 3 circuits at the street to 3 boards in the garage
They had tripping issues so the "solution" was to split it like that with 3 seperate breakers and ELs
When they did a solar install they realised it wasn't true 3phase. I laughed
Yes
odd way to do it , all 3 wires would have to originate from the same phase in the outside box , unless the original single phase cable wasnt big enough to handle demand so they split it up to 3 supply wires to handle the load ,or it was on the edge ,still not a logical way to do it , would work out very expensive , probably more than running a single bigger cable to handle the load .thats the only feasible explanation i can think of .never really seen that before , but i suppose it can be done , nothing that says it cant be done like that .weird .it would be a bit of a juggling act across the 3 separate lines as youre bound by the box breaker size and it wont give you more capacity .
Yes
My best guess is they got conned into splitting to 3 earth leakages but with extra wiring from the street instead of splitting at the board
