With water shortages plaguing the land do you have a backup supply if your taps go dry? If so what?
Do you currently run your house off it?Yes, I have a borehole.
Yes I do.Do you currently run your house off it?
Even a small (1000l) flowbin? They're pretty easy to tuck away in a corner.Unfortunately, I have space constraints, and would need permission from the body corporate to install any kind of back-up. That said, it is probably something that I should be exploring, even it is a small Jo-Jo tank or similar.
Good plan. Things get tricky when you're running off tanks and get loadshedded.Currently have 5000L installed to harvest rainwater, mainly for pool and garden, but will install another 5000L separate that I can use to plumb into the house with a pressure pump etc...right after I get the solar install sorted! Crazy the lengths we have to go to ensure we are safe inside our own property + providing ourselves with basic services!
Here?Here every house has had rainwater tanks since the 80s. I've upped the number of tanks at my place from 5000 to 15000 liters and will probably install another 5000 liter tank next month for the garden. All the tanks are plumbed into the house and all greywater is plumbed to the garden.
I need a constant supply of water to the garden while my food forest is establishing.
Port AlfredHere?
Ok - makes sense. You guys have it worse than most.Port Alfred
While we on this topic - has anyone managed to install a 12V, or similar, booster pump that will provide adequate pressure inside the house + geyser? My PCV valves are all 400kpa so what type of booster pump would I need to ensure sufficient pressure?Good plan. Things get tricky when you're running off tanks and get loadshedded.
Here?
I can run my pump off the generator but it's uses close to half of what it can output.While we on this topic - has anyone managed to install a 12V, or similar, booster pump that will provide adequate pressure inside the house + geyser? My PCV valves are all 400kpa so what type of booster pump would I need to ensure sufficient pressure?
R17k a pop for what? Our tanks worked out at less than R1 per litre storage and that's at the inflated PE panic buying prices.P.S. I have a 5000 litre Jojo which collects rainwater from my roof space. It is amazing when it rains but it has been empty since April so I don't consider that a viable option for a backup water supply. Perhaps if I had 30 or 40kl water storage it would be better suited for Winter use. Again at R 17k a pop I would be looking at 68k just for the tanks. Once you add pumps, filters, plumbing, labour etc. it would probably come to R 150k.
