Yes, Crash is correct, most rouers suppr PPPoE and should work. I'm using a Abocom (Mecer) FWS410 wireless access router. It works like a bomb. just having a few config problems trying to get torrents to work?
when you state does these routers work with i-burst.What do you mean?Can I use for example a d-link di-624 to replace the i-burst modem or are you talking about ussing the d-link to keep the connection .
The iBurst UTD is a PPPoE modem, so you can connect (via Ethernet) any PPPoE client router e.g. D-Link 624+ like mine. Router logs in via PPP, does the NAT & firewalling & extends you iBurst connection via ethernet & WiFi.
