does such a thing exist for IOS?
Jet-Fighter7700
Somewhere Different
Hi guys,
another thing I wanted to ask, is there a way to run android as a "virtual machine" inside IOS?
I mean besides jail-breaking and all that hazards, is there any way to run something that apple might not want on a Ipad.
im thinking torrent and other such programs?
Im sure it must be possible,
Hi guys,
You can use bluestacks on a windows pc as a emulator
I doubt you can setup a virtual environment on iOS to run Android.
Sounds like the easier solution is to just use an Android tablet.
Don't think that is gonna happen, you can't even send songs through watsapp on iOS
I managed actually to do that, but using a wifi program, bypassing itunes and all its problems,
at the very least I can use my VLC on an Ipad, makes life a bit more bearable on this device,
Did someone hold a gun to your head when you bought it?
You can download from Pirate Bay and send songs via whatsapp on an iOS device without jail breaking but of course it's not as straight forward as it is on an android device - no virtual machine required
For sending songs via whatsapp I use a paid app called File Hub. This app has the ability to browse the native music app and select songs or the entire album. Basically you upload the song to the file hub cloud and subsequently "open" in whatsapp and send to your contact
Hi guys,
Just load Kodi on it . Kodi has addons for torrents or you can download streams from some of the other addons
http://www.macworld.co.uk/how-to/io...-or-ipad-without-jailbreaking-update-3634908/
this is my thinking as well,
hard to see the point of these IOS devices TBH,
but yes I want to run utorrent on an Ipad, internet says its not possible, but there must be a way
Are you schitting me!
2016 and iOS devices can't do torrents. O_o
