seven7seven
- Oct 31, 2003
Domain DNS Problems - can't figure out what the cause is? [SOLVED]
Update: It must be a problem on ZoneEdit's side - quite a few people on twitter are saying ZoneEdit's ns2 and ns17 are down. (http://twitter.com/#search?q=zoneedit)
Hi all,
A domain I administer is all of a sudden having DNS issues and I can't figure out what the cause is. Everything used to work perfectly and I haven't changed anything.
The domain is shp.org.za and I'm using ZoneEdit NS's configured as such:
When I do nslookup/dig shp.org.za is correctly returning an A record, and so http://shp.org.za loads the site fine
BUT the following are not working:
www.shp.org.za - no A records being returned/can't resolve this domain
mail.shp.org.za - no CNAME record being returned/can't resolve
MX - no MX records being returned for shp.org.za
Did some checking at http://www.squish.net/dnscheck/ and it showed some errors but to be honest I don't quite understand what they mean! I think it might be a problem on ZoneEdit's side but I'm not sure?
How can I find out what the cause is and then fix it?
All help is much appreciated
Thanks!
Hi all,
Code:
A Records:
shp.org.za 208.75.208.172
[url]www.shp.org.za[/url] 208.75.208.172
Mail Servers (MX):
Domain Server Rank
shp.org.za ASPMX.L.GOOGLE.COM 0
shp.org.za ALT1.ASPMX.L.GOOGLE.COM 10
shp.org.za ALT2.ASPMX.L.GOOGLE.COM 10
shp.org.za ASPMX2.GOOGLEMAIL.COM 20
shp.org.za ASPMX3.GOOGLEMAIL.COM 20
Aliases (CNAME): Alias Actual Domain Name
mail.shp.org.za ghs.google.com
Thanks!
