Done something so basically stupid; help
raycomp
I have just ctr/del an entire directory with vital info in stead of just a sub directory. Desperate for any help or ideas on what to do or use to recover this directory with all files
Operating system Vista Home
Don't try copy or move anything. Get yourself some data-recovery software, it should still be okay.
Thanks for all the prompt replies with positive advise
Previous Versions
I don't know if this works in Vista Home, but if you have system protection turned on, you may be able to open a shadow copy (previous version) of the drive containing the directory.
Select the drive in "my computer", right click and select "properties", then the "previous versions" tab if it is available!
If it is, check for a version from before your "accident", open it, locate your files and copy them back!
