Doogee X5 Max
PatchTuesday
Long Story:
So my grandpa's old phone has taken a nasty fall.
It was a ZTE V967s (540 x 960 px (5.00") 220 ppi,Android JB :sick:) that he liked quite a bit.He gave me a strict budget of R1500 and no more,which i was more than willing to add to,but ultimately shot down as he see's it as wasteful.
His only condition was that it has much better battery life than the old phone (Li-Ion 2500 mAh).Never the less,I set out on a task to find a phone that meets these requirements.Considered the Xiaomi Redmi 2 8GB LTE at R 1,459.
Checked out some reviews but that battery life and Android 4.4.4 KitKat? I mean come on,what year is this?I see i can upgrade to MIUI 8 but that's a shlep,cause it needs to be unboxed,setup and run.
Came across this http://www.doogeemobile.com/doogee-x5-max.html.Pretty impressive for a cheapy.Android marshmellow and a 4000mah battery included.More surprising is that its available locally - https://www.takealot.com/doogee-x5-max-black/PLID43686795
So I bit the bullet and purchased.Turns out the price is R1299 :D,I included this in the order - http://www.takealot.com/doogee-x5-max-x5-max-pro-cover-black/PLID44077515
Leather cover +Tempered glass film for R149 extra.
Total Cost : R1448
Going to collect from the warehouse later today and will let you guys know if its worth it or wet toilet paper:p
Short Story :
Budget+Battery requirement = bought a Doogee X5 Max from Takealot today.
Once collected,will write a short review on the experience,as its for an old person.
The Review is in
Unboxing :
Pretty simple card board box.The phone comes in a plastic sleeve with information on it.
Both the top and bottom of the sleeve are cut out so you can push the phone through either way.
The phone also has a plastic cover on the screen,which i think most phones do.
Theres a 1000mA charger and a micro usb cable and quick instruction booklet.Seems pretty standard.
Initial Impression
This phone is a fair bit heavy,comparing it to this old phone though,its more or less the same weight range so he wont mind.
Its quite thick too.Must be due to the removable battery they've slotted in there.While these may seem like complaints,its more of a so you know thing if you do consider buying it.In my grandpa's case,it really doesn't phase him.
Thats actually where the so called complaints end.The phone doesnt feel like cheap.
It has a hard plastic shell with a type of silver brushed coating all the way around the phone.
The plastics used make it feel sturdy,no doubt adding to the weight
Powering on
Greeted by the standard android boot splash logo,followed by Doogee's boot screen.
It took awhile to boot for the first time.Standard setup wizard one might expect in a vanilla version of android.
Once I added in all the details,I was pleasantly surprised to find that the phone contains no bloat apps.Sure theres apps he is never gonna use,but no Chinese crap i had to uninstall.All official apps from google play store.
Browsing through the settings,theres quite afew extra options too,like this for example; fingerprint gestures (control the camera or gallery or music player with your finger print...sweet).The most interesting is that theres a smart actions tab.Once enabled,it gives you extra configurable options.I enabled "double tap to wake",and it really works too.
The phone only has 3G which shows its "age" compared next to my Xiaomi Note 3,but in real world applications(whatsapp/email and web browsing) you'd hardly notice.Downloading and youtube on the other hand is a different story that we'll come back to.Fortunately i connected it to the home wifi and didnt notice any slow downs.One thing to note though is that it only supports 2.4Ghz networks,unfortunately.
There's a feature under settings that boosts downloads,it combines 3G+ Wifi to make it "faster".I haven't had the opportunity to test this out yet but will update you guys when I do.
Final Thoughts
Aside from the bulkiness,its actually a very decent phone which regular people would be more than happy with for a good price.
I would buy myself one just to muk about with it or keep it as a spare
My wife has the X5 Max Pro (2Gb/16Gb). Very nice phone. She dropped it on its corner the other week and she has a crack above the screen, but doesn't interfere with the screen. Battery last at least 2 days with both sim's active, wifi and bt permanently on.
You will be pleased with the build quality and big screen (you will be able to use a bigger font). I have only bought Doogee phones for the last few years.
May take a few minutes to do the OTA updates. There are a few to get through.
I noticed the overseas suppliers sell this with a 2G RAM whereas local suppliers like Takelot only sells it with 1G RAM. Is this likely to make much of a difference?
Appreciate your comments.
Cash Crusaders are the other local suppliers for Doogee phones. Also bought the X5 but after three days got a thin red stripe on the screen. Was replaced with no problem. Two months on and happy with the phone. Battery life seems OK, 3- 4 days, but had complaints about low volume from microphone when making calls. Seems to be a common problem! Found out how to get into the "Engineering" mode on the phone and adjusted the microphone volume setting. So far no further complaints. Consider the phone excellent value for it's price!!
Update update: Edited original post with info
Where did you find this info if you dont mind me asking?
Might just have to do the same for my GP.Asked him to test drive it this weekend and feedback any issues
If theres anything else i can think of,I'll add it to this post.
If you guys have any questions,feel free to ask.
I'll also try to add pics going forward just to see
I forgot to mention the cover.
That thing makes the phone feel premium.The back battery cover click off the phone and the "leather" one clips on.Has a bery nice feel to it.Doesnt protect the top and bottom of the phone very well though,just the screen area and back.
The tampered glass was very easy to apply and had no issues there
My wife doesn't like the fingerprint sensor and she doesn't use it at all. It seems to run everything, even gets 4G when in the big city.
As an aside, I just looked at the Mix at US$250. Stunning phone! check it out at the Doogee site doogee.cc . That is my wife's new phone for January. I get her a new one every year.
Sounds good.
Do you shipped them in?
Any word on the malware/ads on your wife's phone?I'l be checking my grandpa's phone out this afternoon just to be sure.
Might have to root it and block stuff :whistle:
No ad ware. You can get custom rom's on needrom if you want.
Just ran tests on both the X5 and T5 as well as my old DG700. No viruses or adware found. All running stock FW.
Check the following link:
https://www.youtube.com/watch?v=bMfHM3GkL3c
Lots of info on Utube on this issue.
The engineering code is: • Why the sound(loudspeaker/microphone/receiver) is so weak in my phone?
Please enter engineering mode(press *#*#3646633#*#* on dial) to modify some settings.Find the option “Audio”,you can see many sound option,such as “Headset mode” “Loudspeaker mode” “Speech enhancement”.Choose one of them according to your need and modify the value to a higher one.Note:Please do this carefully and do not change other setting,we are not responsible for damage caused by change setting arbitrarily.
The phone only has 3G which shows its "age" compared next to my Xiaomi Note 3,... One thing to note though is that it only supports 2.4Ghz networks
That is another important difference between the max and the max Pro. The Max Pro does 4G and has dual 2.4/5Ghz wifi. I can confirm this as I have a dual band wifi router at home and last time we were in the city we got 4G.
Ah okay cool cool.Thanks guys.
Checked the phone out,all scans show clear.
I decided to root it anyway and install a firewall on it just in case.Will post a guide for those interested in a while
Camera is ok for an 8MP. Fine for messaging and the like. I wouldn't use it to take my friends wedding pics though.
