Hi folks
Forgive me, I'm far from a DIY fundy...and i'm keen not to injure myself, even though I feel rather foolish about posting for such a simple project,
I've had one of those verimark door frame pull up bars that hooks behind the door frame. Unfortunately our house either has doors without a frame, or a wooden frame on the opposite side to the opening, meaning the door is in the way and I cannot use it.
I wanted to mount a strip of wood on the opposite side to act as the frame support.
Given I cannot go out shopping, I've found a piece of 3cm x 2cm x 70cm pine. Granted pine is not the best wood available but that's what I have.
I also can only find two fixtures, a pair of SX 12x60 wallplugs and 7cm x 7mm diameter screws (bolts?).
- Will just the two screws be enough to support 80kg? The force would only be downwards, so I think the wallplugs should be sufficient rather than expansion bolts.
- Since the screws are quite big, will using them significantly compromise the strength of the pine strip?
- I'm assuming there should be a lintel somewhere above the door, should I aim to drill into it, or above it? Assuming I have a drill bit strong enough to bite into the lintel anyway...
- Anything else I'm not thinking of?
