keng
Both Axxess and Web Africa use the same router settings and I am struggling to set up two different connections.
Have set up the network connections under windows and both work. PROVIDED that I go into the router settings and change the user name and password to the account I wish to use.
Is there any way that I can establish a SECOND connection in the 504. When I select new connection the router moans about the vpi 8 and vci 35 being used
a second time.
So my problem is switching from one account to another. I would like to simply click the desired connection through network connections.
a second time.
