Sm00thSm0k3
- May 8, 2009
Hi all,
I've had my Canon 550D for about 5 years now and just over a year ago I purchased a used Canon 18-135mm IS lens (non STM) as an upgrade from the stock 18-55mm lens.
Over the last few months I've noticed that when I use the 18-135mm lens the camera/lens tends to "front focus" i.e. let's say I'm taking a wide angle shot like one would typically do for a landscape photo, instead of the lens focusing in the center it will rather auto focus on a random object that is closer to the lens. The result of this is that the object in the foreground is in focus while the rest of image is "soft" or out of focus.
This is quite frustrating because one can't really see/detect this while sampling the images on the camera's LCD but it is very obvious when one looks at the images on a PC monitor.
I don't seem to have this problem with the stock lens so I don't know if the 18-135mm lens is malfunctioning or if the camera's sensor doesn't like the lens?
Where should I start looking to try to establish the root cause? Would it be worth my time and money to send both the camera and lens to Canon to be inspected/serviced?
