FireBall2008
Hi,
I recently upgraded my dlink 655 router to a dlink DSR-1000n. I read a lot of reviews and took a while before i decided to go ahead and buy the DSR-1000n. I have since had nothing but problems with it. I have spoken to their tech support in Sweden who emailed me their latest firmware 1.03B74_WW which seems to be a bit better and faster.
My dlink 655 was rock solid, never gave any problem, easy to configure and use. the only reason for my upgrade was the VPN support, firewall features and speed. which is probably the only thing the DSR-1000n is good at.
It is terribly tricky to configure. ie setting up the dedicated ip address, has to be done "manually" unlink the dir-655 you could select this from a drop down list. same goes for the mac filtering, has to be done manually!
The wifi range is better although you have to manually switch betweeen 2.4ghz and 5ghz, it doesnt broadcast this similtaniously. There is not much difference in speed either (between the dir-655 and dsr-1000n) you only notice the speed when you have more than 3 computers connected to your network. the dir-655 struggled where as the dsr-1000n doent break a sweat.
The main porblem is and i have tried to change all the settings and still does it!!!!!!!!!! the dsr-1000n, without fail!! disconnects me from the internet.
The tech support in Sweden told me to disable the udp flood, this didnt help. nothing else seems to help solve the problem.
oh another problem which the tech support didnt have any answers to was the fact that there is only read only access to the usb storage devices which you can connect to the router. you can find these devices on your network and copy fiiles from them but you cannot write to them. again
to be perfectly honest, i dont know why i bothered buying this router the disadvatages far out weigh the advantages.
Has any one else experienced similar issues, i would be interested to know your thoughts.
Simon
Simon
