DSTV Connect lip synch issues
getafix33
Hi
Watching DSTV via the web and continuously have lipsynch issues. Supersport seams to be fine
Any idea what could be the issue
Hi
Hi Getafix33
Do you also find the sync issues on www.dstv.com? Supersport like you said is fine, it's just the LiveTV. I've been in countless conversations with DSTV chat about this, with no resolution of fix. I phoned and still no help. They testing on their side saying that they dont have any delays. I've got two separate internet connections and both are out of sync. I'm also logging in at work with the same sync issues persisting. Have you had any positive response yet?
