DSTV decoder connection question
getafix33
Hi
I was running the older HD PVR 4 tuner decoder with my SD PVR as a secondary in XtraView.
The SD PVR has packed up and I need to replace it.
Are there any decoders available that can be used as a secondary with my HD PVR as a primary. I dont really want to replace my HD PVR as it is working perfectly.
Cheers
Hi
Cheers
I don't think you can. Had that same setup. The HD+SD combo gave you view 3, record 3 correct? Best to look for a used SD-PVR. Not ready to sell mine yet.
Hi
Cheers
If you dont need to record on the second decoder you can get the Single View HD Decoder (i have that set up with my HD PVR as the primary.
If you want to record then the Explora is the only way to go.
