Pitbull
Verboten
I had to drive to my dad's house during lunch as he says his DSTV died...
Drove all the way there to check the cabling and so on. Turns out some channels work fine and other's don't. Some channels says: "Check your installation, if problem persists contact Multichoice" It's a and when I put it on a channel that works the signal strength is 100%, quality 95% (Tuner 1) When I change to a channel that doesn't work it has zero signal and zero strength all the way to tuner 4 then the signal that was on tuner 1 is on tuner 4.
Anyway, dad says it was working this morning and he thinks he pressed a button on the remote the farked it up.
Anyone know what the issue can be? I'll drive there again after work but would like to avoid phoning Multichoice if possible.
