Dstv Dish Required
JV_011_
Centurion
Can someone tell m where can i get a dstv dish. I still have my decoder from years back somewhere
I found it was cheaper to by a new decoder and use the free installation voucher to get it installed. Otherwise you will need bracket, arm/pole, dish, lnb, cabling, connectors, cable clips/glue gun etc
It adds up very quickly.
was 499 at game last month
not sure when it will be that price again
depending on you location you probably would have to buy another dish in 2 years cause its gonna rust . decent bigger 70+cm( better for hd ) will cost you R800 and over for the dish and arm only ( talking aluminium or fibreglass )
