DSTV Explora Remote
drakeSW
hi guys,
I updated my Dstv Remote to support the Explora PVR as well. Press the Android menu button and select the Explora checkbox under settings.
multichoicemote
The app works on Samsung devices with infrared senders, like the Galaxy S4 and the Note 3.
Enjoy!
Regards,
DrakeSW
hi drakeSW ,
installed your app and working fine on Note 3 /Dstv Explora ,
just to report one or two issues,
had a force close and freeze( had to reboot to get out of it )( I forwarded app error report )
but impressed with your app and as stated above it works overall very smoothly !!.
I also had problems changing to the channels 3xx(eg 305..306 etc ,)
it does not want to register the first digit 3 ,
but all other channels i checked seems to change fine also eg ,catchup etc ,no problem so far !
thank you.
