Got a new Explora installed earlier today - went with the new DStv SmartLNB, which has 1 unicable running from it directly into the decoder. (No xtraview or any other decoders set up). The other 3 unused unicable outputs on the SmartLNB are terminated properly.
The Explora tuners show as follows:
Tuner 1: Strength 91%, quality 86%
Tuner 2: Strength 96%, quality 87%
Tuner 3: Strength 84%, quality 69%
I know the Explora shows lower strengths/qualities than the HD PVR's used to - so my question really is, is the above okay? The installer double-checked the LNB as well as the cabling and the connectors, and nothing should account for signal loss.
