DSTV HD Decoder signals
tcofran
Pretoria
SO i got my new decoder (watch 1, record 2) on MOnday, and had it installed on tuesday. If i record, the recordings are very jerky. When i'm recording and i check the Tuner Status, it says the following
Tuner 1 - Signal Strength 100, SIgnal quality 100
Tuner 2 - Signal Strength 0, SIgnal quality 24
Tuner 3 - Signal Strength 0, SIgnal quality 25
Will this cause the problem ? I phoned DSTV and they sent some software upgrade... THey say if it doesnt solve the problem i must take the decoder in to check if the hard disk is not overheating
Any comments will be welcome
Try out http://forum.dstv.com/ for future DSTV queries
Which decoder do you have ? UEC (Silver) or Pace (Black) ?
What happens if you try to record the channel that you are currently watching ? Is the recording jerky as well ?
What LNB do you have ?
How is it installed, twin LNB + multiswitch / SatCR etc ?
Those signal % point towards a dodgy install. You should've checked recordings & signal % before letting the installer leave
Tuners 2 and 3 are only used when recording. So if nothing is being recorded, they will show a signal strength of zero.
My dstv signal strength shows 0% but the signal quality is 100%.
The picture is OK for a hdpvr but this is worrying me. any ideas?
